12-09-2025 10:41 PM
Hello Team,
I have an excel sheet of group record data.I want to create one one individual ola record for each group .
My group data is as follows
| Name | Type | Line / Vendor Manager | Description | Group email | Vendors |
| FIT | incident, request, problem, change | Acer | FIT support group | fitdesk@test.com | |
| IT SERVICE DESK | incident, request, problem, change | Adobe Systems | IT SERVICE DESK group | itservice-desk@test.com |
the below is my ola conditions how it should be created
| Title | Name | Duration Type | Duration | Schedule source | Schedule | Timezone Source | Target | Type | Table | Start | Pause | When to Resume | Stop | When to Cancel | Retroactive Start | Set Start to | Retroactive Pause | SLA Breakdown Config (Assignment Group and Assign to) |
Resolution OLA | Team1-Fulfillment | User specified duration | Breached on 'Due Date' | SLA definition | 8-6 weekdays | The caller's time zone | Resolution | OLA | sc_task | Active = true | State = Closed Complete | State = Closed Incomplete OR Closed Skipped | Yes | Created | N/A | TRUE | ||
| AND Assignment group = Team1 | ||||||||||||||||||
| AND Assignment group.Vendor is Empty |
Now instead of Team1 it should replace the group name for example "FIT" is my group's name.
also in condition also it should build active true assignment group is fit like that.
I want to use transform map and create bulk ola records.
what approach i should do to get his done.
@Ankur Bawiskar any suggestions?
12-10-2025 09:05 PM
correct it will pick the due_date field present on Task table
12-09-2025 11:54 PM
in my upload excel sheet we do not have all the fields we only have name and in target field we have logic only to set those fields as you have explained.
what i should set without the source field match i can't save and can't create field maps.
12-10-2025 01:04 AM
then have field map only for name
then handle every other field in onBefore transform script and set the target field
something like this
(function runTransformScript(source, map, log, target /*undefined onStart*/ ) {
// Add your code here
var condition = 'active=true^assignment_group=b85d44954a3623120004689b2d5dd60a^EQ^';
// if you know group sysId then use that or dot walk to name field
//var condition = "active=true^assignment_group.name=FIT^EQ";
target.setValue('start', condition);
})(source, map, log, target);
12-10-2025 07:54 PM
Hello @Ankur Bawiskar ,
i tried the on before script and it works now but i am not able to set it should breached if due date passes .due date is a field i tried the duration type with different options but it is not working.
| Resolution OLA | InternalTeam1-Fulfillment | User specified duration | Breached on 'Due Date' | SLA definition | 8-6 weekdays | The caller's time zone | Resolution | OLA | sc_task | Active = true | State = Closed Complete | ||
| AND Assignment group = InternalTeam1 | |||||||||||||
I do not think i can provide schedule duration according to the above.
12-10-2025 08:01 PM
Glad to know my approach worked.
you can set duration_type with this sysId in onBefore transform script
target.duration_type = '5d3bf3e5eb5322002a7a666cd206fe8e';
12-10-2025 08:10 PM
@Ankur Bawiskar ,
I need to set the duration type to user sepecified duration and duration to the field that is breached date it means it should get breached on due date field present on sc_task field.
