Issue in flow designer
Sagar Rd
I have created a flow designer on the incident form. Now I need to reload the incident record once the flow designer execution is completed.
Mourya
maroon_byte
What is the trigger of your flow?
I trigger it by button through UI action
Okay, so you are using UI Action to execute the Flow (using sn_fd.FlowAPI.executeFlow)
. If the flow is doing its job but the form is not refreshing, then try adding below line at the bottom of the code or after the update statement.
Harish KM
Hi @Sagar Rd please provide more details on the use case what is the need to reload when flow is completed?
Harish
