Issue with UI Action
Sathwik1
My UI Action is not working in the workspace... can someone please guide what I need to write in the workspace client script?
@Ankur Bawiskar  @Dr Atul - LNG
@Sathwik1
any update to this?
Deėpak Sharma
Hi @Sathwik1
Replace the code in the Workspace Client Script field (bottom box) with this:
function onClick(g_form) {
    // 1. Clear previous error messages
    g_form.hideFieldMsg('close_notes');
    g_form.hideFieldMsg('resolution_code');
    var isValid = true;
    if (g_form.hasField('resolution_code') && g_form.getValue('resolution_code') == "") {
        g_form.showFieldMsg('resolution_code', 'Resolution code is required.', 'error');
        isValid = false;
    if (g_form.hasField('close_notes') && g_form.getValue('close_notes') == "") {
        g_form.showFieldMsg('close_notes', 'Resolution notes are required.', 'error');
        isValid = false;
    if (!isValid) {
        g_form.addErrorMessage('To close a case, you must select a resolution code and add resolution notes.');
        return; // This stops the submit from happening
    g_form.submit('resolve_case');
not need to change the Server Side code (lines 19+ in your screenshot). Once g_form.submit() runs successfully, it will trigger that server code automatically.
Happy to help! ‌‌
To help others in the community find this solution, kindly mark this response as the Correct Answer ‌‌ and Helpful‌‌.
Warm Regards,
Deepak Sharma
Community Rising Star 2025
Return should not be used in the client side.. it blocks some other OOB UI Action.
Open the respective table.. and from form header. right click on it.. it wont work.
