How to update [ glide.email.smtp.max_recipients ] property?
REI UEYAMA1
Giga Expert
Hello -
We have a requirement from our client to send a bulk email to 175 users via Flow Designer.
Flow log shows that.
So,I tried to update  [ glide.email.smtp.max_recipients ] property to configure its limit number to 200.
Unfortunately , I can not  find its property in [sys_properties]table.
【Question】 What system property controls this maximum number? To solve the error, what should I do?
Any help would be greatly appreciated!
Mark Roethof
Hi there,
You can add the system property and provide your own value. System default is just 100.
Question though: when setting this to 175, and then suddenly the customer has more recipients, are you then going to change the system property again and again and again?
Or can you think of a different solution? Sending multiple emails to max 100 recipients? Or an email to a mailing list? Etc..
Kind regards,
Mark
2020-2022 ServiceNow Community MVP
2020-2022 ServiceNow Developer MVP
LinkedIn
Community article, blog, video list
Kind regards,
Mark Roethof
10x ServiceNow MVP
LinkedIn
Thanks!
To create new [sys_properties]record in that way,  I could send email to 175 users.
