Add Assignment group choice to Problem Form
David Santel
Giga Guru
My assignment groups are not showing up for problems. How do I populate the same assignment groups for problem that i have setup for incidents.
Hi David,
There is a field called "Type" on the Group form. Press the security lock icon next to it and you'll see a search box. Type in "Problem" and then select to add as a group "Type". Press the security lock icon to close the type box then Save the group record.
Navigate to the Problem table and check if the group you just assigned the "Problem" type is now showing as an assignment group.
Brent
16 REPLIES 16
Hi Brent,
Where do i go from here? Sorry im very new.
Hi David,
You need to add the "Problem" type to the groups that need to show as assignment_groups on the problem table.
Navigate to System Security > Groups > Select the group that you want to see as an Assignment group on the Problem table.
Add the "Problem" group "Type" to this group:
Navigate to the Problem table and test if that group is now shown as an assignment group. If it shows up then you can add the "Problem" type to all other groups that need to be shown as assignment_group's on the Problem table.
Hope that makes sense,
Brent
P.S. If my suggestion helped then please mark as helpful and/or correct so other community members can benefit from this information.
