Approval approved/Rejected notifications not working
GB14
We have 2 notifications on the AST_CONTRACT table.
1) Contract approved
2) Contract rejected
These notifications are not triggering an email when a contract is approved or rejected.
I tried to trigger it via an event, based on conditions, but these notifications won't trigger.
Any suggestions will be appreciated.
G
If it is triggered by Record Updation, then Creating an Event won't work.
Everything from your screenshots looks good to me. I hope you have some text in the 'What will it contain' section Subject as well as Email Body, and some user value populated in the 'Created By' field. If  either of those are absent, then the notification won't send.
You can also try Previewing Notification.
I hope you are checking the System Logs > Emails module some seconds after updating the Record status to Rejected. Sometimes, the notifications don't get sent immediately.
9 REPLIES 9
Created by field is not visible on the form but the XML is showing the values. Showing the user's ID.  If I add another user reference field then it works.
Does the field have to be visible for it to trigger the notification?
G
I don't think so. Perhaps that user is inactive?
Created By is a string field. any suggestions on how we can use the OOB field?
Got it working. 😄
Created a flow to copy the sys_created_by to a custom field.
Then updated the notifications to send to the new custom field
Worked without any issues. Thank you for your assistance.
Glad to know it worked. But why is created by a string field? Strange lol.
