How to Copy Approval comments into RITM, REQ
chanikya
can you help me how to copy Approval comments into RITM, REQ, when RITM was REJECTED.
Not Working
here Approvals comments copying to RITM, but  Not  copied into REQ.
approvalcomments();
function approvalcomments()
var grr = new GlideRecord('sc_req_item');
grr.get(current.sysapproval);
grr.comments = current.comments;
grr.update();
var gr = new GlideRecord('sc_request');
gr.get(gr.request);
if(gr.next())
gr.comments = current.comments+" " +gr.number;
gr.update();
Working example from my PDI (= tested). Working for Approvals on RITM.
Kind regards,
Mark
LinkedIn
13 REPLIES 13
Looks pretty oke. Only one thing: I don't think the ghh.get will work. Change it into ghh.addQuery.
ghh.get('request',gr.sys_id);
into
ghh.addQuery('request',gr.sys_id);
(where gr.sys_id is actually the same as current.sysapproval)
Kind regards,
Mark
LinkedIn
I used the above solution and it works great. My business rule didn't have a state condition, just copy the contents regardless. The only thing I noticed is that if the approval goes to a group, it will try to copy the comments from each approval record. So if the group has 5 people who could approve, it has 5 additional actions that say comment copied from approval record and only 1 will have comments in it. I know this is old, but is there a way to restrict to only grab contents from the approval record that approved it?
Jyoti8
Hi chanikya,
These link might help you.
https://community.servicenow.com/community?id=community_question&sys_id=3dfc8369db9cdbc01dcaf3231f96...
https://community.servicenow.com/community?id=community_question&sys_id=092d43a9db9cdbc01dcaf3231f96...
If I have answered your question, please mark my response as correct and/or helpful so that others with the same question in the future can find it quickly and that it gets removed from the Unanswered list.
Thank you.
in case if WE have REQ level Approvals presented on REQ, then is it correct???
reqapprovalcomments();
function reqapprovalcomments()
var gr = new GlideRecord('sc_request'); // if REQ had approvals
gr.get(current.sysapproval);
gr.comments = current.comments;
gr.update();
var ghh=new GlideRecord('sc_req_item');
ghh.query();
while(ghh.next())
//gs.addInfoMessage("RITM numbers is"+ghh.number);//
ghh.comments=current.comments;
ghh.update();
