How to hide values of subcategory
vivian08081
Giga Expert
So far we have plenty incident tickets already existing in our instance. We don't want to deactivate any value from subcategory.
Just want to users could not see them from the drop down list.
I try to use client script - onChange - g_form.removeOption('subcategory','email') to implement this. But it doesn't work for the reference fields like subcategory..
Does anyone have any idea to implement this?
Hi Wei,
I have tried below and it works, let me try to explain in details if this helps. Created a column (Right Click on the list header then configure -> List Layout) on sys_choice table and then create a new column Choice Not Needed (true/false type) and set the value to true for the records which you don't want to display. Refer the screen shot below.
then create a script include with below code. You might need to fine tune the code based upon your field name.
var GetListValue = Class.create();
GetListValue.prototype = Object.extendsObject(AbstractAjaxProcessor, {
getList : function()
var ids = [];
var gr = new GlideRecord('sys_choice');
gr.addQuery('dependent_value', current.u_category.value); //Considering category is also a reference field.
gr.addQuery('name', 'incident');
gr.addQuery('u_choice_not_needed', 'false');
while(gr.next())
ids.push(gr.sys_id.toString());
return 'sys_idIN' + ids;
type: 'GetListValue'
and then set the reference qualifier on subcategory field like below.
Result: It's displaying the value of subcategory for which Choice Not Needed is set to false
27 REPLIES 27
Thank you for you help, one more question
I couldn't find the reference specification section displayed on my instance.But it does have.
How to let it show on incident form??
it will be available in reference type field
You need to change the field type from String to Reference.
When I modified the reference specification, then submit it, I got the following error message. Do you know how to fix it?
may i know why you want to change the ootb field type. it will impact all the tables who has extended it .
