How to populate reference field using transform map script on the target table?
Ujjwala1
Hello Experts,
I have been trying to populate reference field value using transform map script, but it is not giving me exact output.
Could anyone suggest me any changes  in the script so that field will take correct cafe value, Any suggestions much appreciated!
Thank you in advance,
Ujjwala
I am using below script in the run script section
 * For variables go to: http://wiki.service-now.com/index.php?title=Import_Sets_portal
var cafe = new GlideRecord('u_tsc_restaurants');
cafe.addQuery('u_tsc_restaurant_number', source.u_store_name);
cafe.query();
if (cafe.next()) {
    var sys_id = cafe.sys_id;
    gr.initialize();
    // target.u_tsc_restaurant = source.u_store_name;
    target.short_description = " Test Tickets";
    target.category = "Online";
    target.u_tsc_type = "Menu";
    target.u_tsc_subclassification = "Enable";
    target.assignment_group = " ";
    target.contact_type = "email";
    // gr.insert();
I have written field map script also, still it is not working
Sulabh Garg
Hi ujjwala,
Try to write your script as below under run script and it should insert a record in Incident table.
cafe.query();
if (cafe.next()) {
    gr.initialize();
    gr.u_cafe = sys_id;           // If you have reference field of Cafe on Incident table, add this line
    gr.short_description = " Test Tickets";
    gr.category = "Online";
    gr.u_tsc_type = "Menu";
    gr.u_tsc_subclassification = "Enable";
    gr.assignment_group = " ";
    gr.contact_type = "email";
    gr.insert();
Please Mark ✅ Correct/helpful, if applicable, Thanks!!
Sulabh Garg
Sulabh Garg
Hi ujjwala,
cafe.query();
if (cafe.next()) {
    gr.initialize();
    gr.insert();
Sulabh Garg
