Populate 'assigned to' field based on assignment group in catalog item.
Apex Predator
Kilo Expert
I am using Orlando version.
I created a catalog item with 'assigned to' and 'assignment group' as reference fields.
I only want to see the users in assigned to field who are part of the selected assignment group.
I created a Script Include 'ReferenceQualifierUtility' which returns a list of users based on the group selected. Attached a screenshot of it.
Script Include:
I created an advanced reference qualifier on 'assigned to' field. Screenshot attached. But still, the assigned to field shows all users even after selecting the assignment group.
Is there another way to do this? Or am I making a mistake?
Referenced this article but to no use:
https://community.servicenow.com/community?id=community_question&sys_id=65d147a9db98dbc01dcaf3231f96...
Thank you community.
Script which is easy to copy/modify:
var ReferenceQualifierUtility = Class.create();
ReferenceQualifierUtility.prototype = {
    initialize: function() {
	assignedDependency:function(){
		gs.info("This is a test message");
		var group = current.variables.assignment_group; // your assignment group variable name
  var user_array = [];
  if(group!=''){
  var getMembers = new GlideRecord('sys_user_grmember');
  getMembers.addQuery('group',group);
  getMembers.query();
  while(getMembers.next())
  user_array.push(getMembers.getValue('user'));
  return 'sys_idIN' + user_array.toString();
  else{
  return 'active=true';
    type: 'ReferenceQualifierUtility'
I assume your 1st variable refers to sys_user_group and name is assignment_group
2nd variable refers to sys_user table
it should work fine
Did you print the logs in script include
Also try using toString()
assignedDependency:function(group){
gs.info('group is' + group);
if(group!=''){
getMembers.addQuery('group',group.toString()); // updated this line
getMembers.query();
gs.info('user array is' + user_array);
else{
sudha20
its working. thank you
