08-31-2019 10:04 AM
I need to created a breakdown for a catalog item variable. Need help as the data is not showing up in the breakdown. I am new to PA advance reporting.
I have a variable name as "Server Name" referring to cmdb_win_server the requirement is for created breakdown for this:
Created break down source and mapping :
and the scripted mapping is:
Log 1 and Log 2 is running successfully Log 3 is giving java error:
Can anyone help me on this and guide me 🙂
Thanks in advance.
Performance Analytics
09-01-2019 01:38 AM
Hi Kriti,
you are not querying "cmdb_ci_win_server" table in line number 9 properly
change it to below use get method and not getValue() while querying
grChoice.get('name', grReq.variables.u_ci.getDisplayValue());
Mark Correct if this solves your issue and also mark Helpful if you find my response worthy based on the impact.
09-08-2019 09:28 AM
Hi Adam,
Thanks for sharing the best practice tips. Could you please elaborate on how can the same requirement to achieved by a view without querying? Because this is kind of interesting to know how can this be achieved for a breakdown.
Answer for point 2. This a POC I am trying to do to see how can we create a Breakdown on the catalog variable referring to some service now table.
Your suggestions are welcomed!!
09-08-2019 12:51 PM
It would be very similar to what you need to do to setup Text Analytics. Take a look at this blog post for how to set up the database view: https://community.servicenow.com/community?id=community_blog&sys_id=9c46571ddbf7a7c0fff8a345ca96194e
