02-11-2025 08:52 PM
Dear experts,
I would like to add in or change the current risk event lifecycle workflow under the advanced risk management scope. May I know what is the diff between workflow studio and editor? So where and how should I approach this customization? Do I do it under workflow editor or studio? Because currently the workflow studio has the risk event approval workflow but workflow editor do not. Waiting for your reply. Thank you.
02-11-2025 09:12 PM
Hi @ChuanYanF
The workflow is currently triggered by the response template under "Administrations", you need to modify the workflow in Workflow Studio by introducing a new approval step after the first approval.
Follow the below verifications:
- Open the Risk Event Approval Workflow in workflow studio.
- Check how the first approval is triggered and what happens afterward.
- Check response template under Administrations is related to the workflow trigger.
- find where the first approval step is defined then.
- add a new decision point or approval step. This step will act as your secondary layer.
02-11-2025 09:12 PM
Hi @ChuanYanF
02-11-2025 09:53 PM - edited 02-11-2025 09:54 PM
Thank you for making a post helpful, please mark as solution accepted to close this thread.
02-11-2025 10:46 PM
I still could not find a way for me to add in a secondary approval workflow as a new stage inside the current risk event lifecycle stage.
