Max Length on String Field ?
sukran
I have a request to increase the string field value from 80 to 500 in the problem table
If i change it took more time and doesnt change to 500
Is this any global or data loss impact will happen ? or how to achieve this
Deleting will make you loose the data.
What you can do is...create a new column...with length 500. then copy the data from old fiedl to new, and then delete the old field.
-Anurag
After increasing the size up-to 500 and save , The page has hang for some time with blank screen and value of 500 not updated in the column , its shows same 80 only.
Shall i delete the column and create new one ?
-Anurag
Yes we can create new one with 500 maximum length value
