10-14-2020 05:43 PM
Is it possible to trigger a Flow Designer when a record is deleted?
Also, is there a way to trigger a flow designer when an amount is changed? I don't see an option to select "Changes"
Thank you in advance.
Flow Designer
10-14-2020 09:03 PM
No you cannot trigger flow for delete operation as the record won't exist.
You cannot trigger when Amount Changes.
I believe it is not supported currently OOB for Price or Amount field type.
you can trigger the flow via after update BR which would be having the condition for amount changes
Sample script below
// Map inputs. For a flow with a record trigger, inputs are the record and table
var inputs = {};
inputs['current'] = current; // GlideRecord of table:
inputs['table_name'] = 'incident';
// Execute the global flow called test_flow
sn_fd.FlowAPI.executeFlow('global.test_flow', inputs);
Reference: Scripting with Flows, Subflows, and Actions
10-15-2020 03:16 AM
Thanks for marking my response as helpful.
Let me know if I have answered your question.
If so, please mark my response as correct & helpful so that this thread can be closed and others can be benefited by this.
