Flow Designer - need help with sending email
JLeong
Hi Guys,
I need to send an email from a Flow Designer. The email must contain the values of a list collector. I need help adding these values to the body of the email.
Example email:
Hi Joe,
Request #123456 has been completed. You are now the owner of the following accounts:
  1. List collector value 1
  2. List collector value 2
  3. List collector value 3
Please assist.
Thank you!
Jocelyn
@JLeong
you cannot use For each loop directly on list collector variable.
you will have to convert String and return String Array which can then be used in For Each
Refer below links for help and the steps
Flow Designer
How to iterate an Array.String in the flow designer?
11 REPLIES 11
Hi Ankur,
I ended up creating an Event in the Flow Designer to call the email notification.
The email script displays the list of accounts.
 Thank you for your assistance as always.
@JLeong
Great!  It looks like you marked your own response as the correct answer, which may be confusing to others that read this later.
Would you mind marking my response as helpful & correct if I was able to help you.
