Flow Designer Response Body
Michael48
I need help get the value of two fields ball and cat from the flow designer. but the script i currently have is not populating the field.
This is a sample of the Response body below
   "key": "xxxxx",
   "keyName": "xxxx",
   "operator": "equals",
   "resultSet": [
         "field_A": "watch",
         "field_b": "green",
field_C": "white",
field_d": "German",
"rowCount": x,
"rowLimit": "xxxxx",
"tableName": "xxxx"
Below is the Script am using in the script step to extract the fields b and C but its not working
function execute(inputs, outputs)
if (inputs.status_code == '200')
// Create an object from the JSON response
var responseObject = JSON.parse(inputs.response_body);
//Write values from the object to the output variables
outputs.environmental_category = responseObject.resultSet.field_A;
outputs.collector_date = responseObject.reultSet.
field_b
)(inputs, outputs);
PLEASE WHAT AM I DOING WRONG AND PLEASE CAN YOU HELP ADJUST MY SCRIPT
Anil Lande
Please try below:
 outputs.environmental_category = responseObject.resultSet[0]["field_A"];
 outputs.collector_date = responseObject.resultSet[0]["field_b"];
)(inputs, outputs);
As resultSet is an Array you need to access it with index resultSet[0]
Thanks.
Anil Lande
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
Ankur Bawiskar
it would be nice if you share the complete json string
Anil Lande
Please try below:
)(inputs, outputs);
Thanks.
Anil Lande
Anil Lande
Thank you it worked and solved my problem.
