how to map reference field in record producer to incident reference field
Nitesh Chandana
Kilo Expert
I need to map to reference field (name) mapped to caller_id(caller) in incident form also reference.
current.caller_id=producer.caller_id and current.caller_id.sys_id=producer.caller_id     is not working
Can anyone correct/modify it please
Nitesh
17 REPLIES 17
I mapped, but record is updating///
What do you mean by record is updating ? Can you please eloberate ?
Can you please elaborate your requirement?
if you will map the variable with the field. it will show the same value that you have selected on record producer form.
Harshvardhan
I mean to say record is not updating even though i mapped variable and field.
can u guys have any alternative?
have you selected the right table in reference field?
on variable and form field should be same table name. i mean to say both are reference field and that is referencing to some table. so please check.
