Is there a way to stop flow designer from running
JLeong
Is there a way to stop a flow designer from running?
example:
setWorkflow(false);   //Do not run business rules
autoSysFields(false);  //Do not update system fields
Thank you!
Hi Mark,
Yes it triggered.
Orlando Patch 7
I am not sure any additional options are available on flow properties because I couldn't find it.
Script:
gr.initialize();
gr.setWorkflow(false);
var sysId = gr.insert();
gs.info(sysId);
Flow:
Output:
13 REPLIES 13
Mark Roethof
Hi there,
setWorkflow(false) actually already prevents Flows from running. setWorkflow(false) is not intended only for Business Rules.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
LinkedIn
Community article list
Mark Roethof
Hi there,
Did this solve your question? Or do we need to follow-up on this?
Please mark this answer as correct if it solves your question. This will help others who are looking for a similar solution. Also marking this answer as correct takes the post of the unsolved list.
Thanks.
Kind regards,
Mark
LinkedIn
Ankur Bawiskar
@JLeong
You cannot stop flow from triggering using setWorkflow(false) since the flow engine is a scripted engine.
refer link below
Using setWorkflow(false) doesn't stop Flow Designer flows from executing?
Ankur,
Did you also test this? I mean I tested this, and it does stop the Flow from triggering.
You are also referencing a topic from a year old. Since then, a lot of changes have been applied on Flow Designer. For example the change in working on the "Run Business Rules" checkbox.
Kind regards,
Mark
