11-04-2020 07:21 AM
Is there a way to stop a flow designer from running?
example:
setWorkflow(false); //Do not run business rules
autoSysFields(false); //Do not update system fields
Thank you!
Flow Designer
11-05-2020 10:49 PM
Hi Mark,
Yes it triggered.
Orlando Patch 7
I am not sure any additional options are available on flow properties because I couldn't find it.
Script:
gr.initialize();
gr.setWorkflow(false);
var sysId = gr.insert();
gs.info(sysId);
Flow:
Output:
11-05-2020 10:49 PM
Hi Mark,
Yes it triggered.
Orlando Patch 7
Script:
gr.initialize();
gs.info(sysId);
Flow:
Output:
11-06-2020 04:08 AM
Thanks for marking my response as helpful.
Let me know if I have answered your question.
If so, please mark my response as correct & helpful so that this thread can be closed and others can be benefited by this.
11-24-2021 05:27 AM
Hi
So now will the statement, 'gr.setWorkflow(false);' can stop the flow which is execution for the gr record?
Could you please update on this?
11-06-2020 04:12 AM
Hi there,
Did this solve your question? Or do we need to follow-up on this?
Please mark this answer as correct if it solves your question. This will help others who are looking for a similar solution. Also marking this answer as correct takes the post of the unsolved list.
Thanks.
Kind regards,
Mark
2020 ServiceNow Community MVP
2020 ServiceNow Developer MVP
11-06-2020 04:44 AM
Thanks Mark and Ankur!!!
Appreciate your time and help!
