manual creation of de-duplication task possible with running any script?
skumar_srbh
any possibility that an ServiceNow user, without admin access can create de-duplication task?
Many Thanks!!!
9 REPLIES 9
Scott Oglesby1
Giga Contributor
Hi Stephen - I appreciate the reply. I apologize for the delay in responding, as my ServiceNow alerts didn't let me know of the reply posting.
If I'm understanding the documentation correctly, I would need to:
  1. Have the ability to access the 'Scripts' module in ServiceNow
  2. Add the following code snippet to the Script Area:
    var taskSysId = new CMDBDuplicateTaskUtils().createDuplicateTask("");
    gs.print(taskSysId);
  3. Go to the CI Class Manager and get the sys ids of the CIs in question
  4. Put the sys ids of the CIs in a comma-spaced format in the script above in between the quotes for createDuplicateTask("")
  5. Click on 'Run Script'
  6. Review the manually created de-duplication task.
Is that correct?
If so -
  1. What permissions / roles are required to access the 'Scripts' module? I don't have visibility to it now in our instance.
  2. Are the steps above the only way to manually create the de-duplication tasks?
Thanks for your time.
Scott
I found this in the community board:
https://community.servicenow.com/community?id=community_question&sys_id=9650283bdbc994504819fb243996...
Is this valid?
Scott
Yes that is. ACL is in place to avoid manual creation of that tasks. It should be created by de-duplication or IDR engine.
Ashutosh
Actually, the question was whether or not the process identified in the article was valid for having the ability to manually create a de-duplication task. I need that for creating de-duplication tasks when the platform does not create them automatically.
Scott
At a cost of creating a new ACL to allow creation on this table.
Ashutosh
