Problem with client script and script include comparing dates
patricklatella
Hi Community!
I've got a date field in an order guide that I want to add a field message to if the value of this field is less than 7 business days in the future.   I've got a catalog client script and a script include for this.   Problem is that (seemingly) random dates in the future that are more than 7 business days are triggering the field message.
Notice in my screen shots that the message is showing for a date way out in May, but only on that day, and not the date 1 day before or after.   Odd??   Anyone see a problem in my scripts below, or have a better way to achieve my goal?   Is there an OOTB GlideDateTime API method that I could use instead?   thanks!
Here's my client script:
g_form.hideFieldMsg('needed_by_date');
/************* This Checks whether the selected date is within 7 business days ahead**********/
  var ga = new GlideAjax('ClientDateTimeUtils');
  ga.addParam ('sysparm_name','withinBusinessHours');
  ga.addParam ('sysparm_hours','54');
  ga.addParam ('sysparm_requestedDate',newValue);
  ga.getXML(CheckScheduleAgainstDatesParse);
  function CheckScheduleAgainstDatesParse (response) {
  if(answer == 'False'){
                      g_form.showFieldMsg('needed_by_date','You are requesting a new user setup too close to their scheduled start date.   Please be advised that IT equipment cannot be guaranteed on their first day.','error');
and here's my script include "withinBusinessHours" function:
withinBusinessHours: function() {
var retVal; // Return value
var pn     = this.getParameter('sysparm_hours');
var requestedDate= this.getParameter('sysparm_requestedDate');
var reqDateTime = new GlideDateTime(requestedDate);
gs.log(reqDateTime);
if(pn > 0){
    //Get a schedule by sys_id to calculate duration
var schedule = new GlideSchedule();
schedule.load('090eecae0a0a0b260077e1dfa71da828');
    //Get the current date/time in correct format for duration calculation
    var actualDateTime = new GlideDateTime();
    actualDateTime.setDisplayValue(gs.nowDateTime());
//Create variable to capture the date we want to compare against
//requestedDate = new GlideDateTime("2017-06-16 00:00:00");
//Date difference calculated based on specified schedule
var difDay = schedule.duration(actualDateTime,reqDateTime).getDayPart()*24;
var difHour = schedule.duration(actualDateTime,reqDateTime).getDurationValue().split(':')[0].substr(-2);
var dif = difDay + parseInt(difHour.replace(/^[0]+/g,""));
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
No. It was parseInt. Use the code I just posted. It should be fine now.
var pn     = Number(this.getParameter('sysparm_hours'));
if(pn > 0){
gs.log('+++++++++++++actualDateTime+++++++++++'+actualDateTime );
gs.log('+++++++++++++reqDateTime+++++++++++'+reqDateTime );
gs.log('+++++++++++++difDay +++++++++++'+difDay );
gs.log('+++++++++++++difHour+++++++++++'+difHour);
var dif = Number(difDay + Number(difHour));
gs.log('++++++++++++++++++Total Hours ++++++++++'+ dif);
gs.log('++++++++++++++++++hours to compare   ++++++++++'+ pn);
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
32 REPLIES 32
SanjivMeher
Mega Patron
Run this and let me know what you see in the logs
if(pn > 0){
var difHour = schedule.duration(actualDateTime,reqDateTime).dur.getByFormat('HH');
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
Hi Sanjiv,
ok I actually created a new script include for just this function.   when plugging it in to the client script and changing the value of the date field a couple times I got this from the log
Some more correction. try this
if(pn > 0){
var difHour = schedule.duration(actualDateTime,reqDateTime).getByFormat('HH');
gs.log('++++++++++++++++++Total Hours ++++++++++'+ diff);
if(dif >= pn){
retVal = "True";
retVal = "False";
gs.log(retVal);
return retVal;
patricklatella
might help to know the date entered...here's another one with corresponding log results
