Instance suspended
dave2477
Hello.   We have a dev instance (dev281) that we use all the time, and it recently started getting this message when we go to it:
dev281.service-now.com is currently in a suspended state. Please reach out to your sales contact to re-enable your instance.
How can I un-suspend it?
Dave
David_Gatley
Mega Guru
devXXX.servicenow.com instances were a part of the Certified Integration Program which has been replaced by the Technology Partner Program. These devXXX instances are out of band with the currently supported n-3 release support within our program. To regain technology partner instance access please visit tpp.servicenow.com, ensure you are up to date with our program agreements and guidelines and use the new Vendor Instances that are a now available for scoped application development.
If you have any specific needs for this, please contact technology.partners@servicenow.com
Hi David, devXXX instances are no longer supported and cannot be reclaimed. You can get a new vendor instance (venXXXXX) within TPP to resume your work.
Okay, thank you!
