12-26-2025 09:01 AM
Hi, I just wanna say that I am very new to Snow and I'm just getting to know the platform.
I got assigned the following task:
I would like the category and subcategory of incident to carry over to change records when a change is created from an incident record.
In the incident form, I have the change request related list in which I can submit a new change by clicking the New button. This button redirects me to sn_chg_model_ui_landing.do, not to the change_request.do page. How do I manage to carry over the cat and subcat from my incident? I know I can do it via params in the URL:
But it doesn't work when I select the model from the sn_chg_model_ui_landing.do. Any help?
12-28-2025 09:06 PM
Hi @ernestogome
you can try with before Business rule to map the category and subcategory from incident to change but make sure the value of the category and subcategory of incident and also change is same.
if yes then try this way
Table: Change Request (change_request)
When: before
Insert: Checked
Condition: parent is not empty.
Script:
var parentRec = current.parent.getRefRecord();
if (parentRec.isValidRecord() && parentRec.getTableName() == 'incident') {
// Copy the values
current.category = parentRec.category;
current.subcategory = parentRec.subcategory;
})(current, previous);
If this information proves useful, kindly mark it as helpful or accepted solution.
BK
12-28-2025 09:23 PM
see when you click New button in related and when new CHG form is opened if INC sysId is there in URL
if yes then extract that and then query it in display business rule on change_request and use that to get category subcategory and set it on CHG
01-01-2026 10:18 PM
Hello @ernestogome ,
Since you got the SysId, you can do a GlideAjax() call to the Server side and get the details.
Najmuddin
01-07-2026 03:13 AM
Hi @ernestogome,
Try to use the business rule for the change in category and subcategory; using the below actions will help you for the solution.
When: before
Insert: Checked
If you find my answer useful, please mark it as Helpful and Correct 😊
Soham Tipnis
ServiceNow Developer || Technical Consultant
LinkedIn: www.linkedin.com/in/sohamtipnis10
