Look up select box reference qualifier not sorting by sequence
Debasis Pati
I have a look up select box variable on my record producer called subcategory which is depend on another variable category.
Now i have created a look up select box variable and used the referecnce qualifier below still its sorting alphabetically not by sequence field on sys_choice table.
@Ankur Bawiskar  Can you please guide what can be done to achieve this?
Debasis
11 REPLIES 11
@Debasis Pati Remove the variable attributes. It's not required.
Done it still its sequencing alphabetically only
@Debasis Pati
did you try with only order by and not making subcategory dependent on category?
Hey Ankur,
I have removed the dependent value and tried just the order by but still same it's not sorting according to sequence
@Debasis Pati
It did work for me
javascript: 'ORDERBYsequence^element=category^name=incident';
Variable Config:
Choices:
Output:
