Need help in Number field
Pihu1
Hi Community,
I have a requirement where I need to change the prefix of Number field onchange of a field. For example if State changes to 'XYZ' the prefix should be 'ABC' and if the state changes to 'TEST' the prefix should be 'abc'.
How we can achieve this?
thanks in advance.
 Pihu
shloke04
Hi @Pihu
Agree to what Mark has said and would suggest altering number is not a good practice to set it to something apart from what has been set in Number maintainenence table as it can cause issue with multiple starting number for different records present on the same table.
Also would make it difficult for user to search and they might not be aware that there are set of records which starts with custom string like abc
But still if you want, you can write a on Change client Script on State field and use the script below:
		if(newValue == 2){
			var getCurrentNumber  = g_form.getValue('number');
			var extractDigit = getCurrentNumber.substr(3,getCurrentNumber.length); // Replace 3 with the number from where your current number digit is starting. Like for example I have done this for Incident table where number currently starts with "INC0010126" so I am eliminating INC
			var updatedNum = 'abc' + extractDigit;
			g_form.setValue('number',updatedNum);
Result:
Shloke
Shloke
Pihu1
Thank you Shloke for all the replies.
