Data and Analytics
cancel
Showing results for
Show  only  | Search instead for
Did you mean:
Browse the Community
Activity in Data and Analytics
SG‑Meraki Integration – Import Sets Stuck in Loading
Hi Team,We are facing an issue with the Service Graph Connector for Meraki (SG‑Meraki).  Issue SummaryImport sets (x_caci_sg_meraki_merakidevices) are frequently getting stuck in Loading stateSome import sets are marked Processed but contain 0 record...
  • Question
Best practice for Managing powered off Servers in servieNow
We have several powered-off servers in our environment and would like your guidance on how these should be updated in ServiceNow.Could you please advise whether the Operational Status should be updated to Non-Operational and the Installed Status to A...
  • Question
Discovery Automation
 HI Experts,I am working on the automation part of ITOM. Requirement is: Suppose We get the alert through Event Management that the VM in the Cloud is not in use for last 6 months. So we need to remove that VMs from the cloud. So How we create a conn...
  • Question
Resolved! Rejecting a Major Incident Candidate via API
Hi Folks, I'm looking for a way to reject major incident candidates via API. The context is, I have an automation that creates P1 incidents. P1 incidents are automatically proposed as a major incident. So, I would like the automation to also reject t...
  • Question
CMDB data management retire policy
Hello Community, I have configured CMDB retire policy and also tested it, my question is when the CMDBtask is not in closed state, we are able to see the CI records that are included in the task, but when the task is approved/ closed suddenly the rec...
  • Question
Relationship is missing in CSDM view
I have related an instance to a business application and it shows on the default view of the instance and on the business application but it does not show in the CSDM view of the instance. Why?
  • Question
CMDB
When a parent CI is retired, its associated child CIs are expected to follow the same lifecycle state. However, a key concern is that these CIs (both parent and child) may have dependencies with other servers, applications, or services within the env...
  • Question
CMDB
Hi Everyone,I want to start learning CMDB in ServiceNow. Could anyone suggest the best place to begin and the topics I should learn first? It would be helpful if you could provide a learning path or recommend any useful resources for beginners.Thank ...
  • Question
Please tell me about best practices for API integration.
Dear ExpertsI'm a beginner at API implementation.Please tell me about best practices for integrating data from ServiceNow via API.① API integration between ServiceNow and external SaaS② Integration between ServiceNow and our internal environment ※For...
  • Question
Getting started
We want your journey here to be as great as can be, so we have put together some links to help you get quickly familiarized with the Community.
