Onsubmit script is not working with script
is_12
Hello Community !
function onSubmit() {
    if (g_user.hasRole('sn_customerservice_agent')) {
        var ga = new GlideAjax('catalogUtils');
        ga.addParam('sysparm_name', 'hasExistingRITM');
        ga.addParam('sysparm_account', g_form.getValue('account'));
        ga.addParam('sysparm_userId', g_form.getValue('contact_name'));
        ga.addParam('sysparm_catalogItem', g_form.getUniqueValue());
        ga.getXMLAnswer(setData);
    function setData(response) {
        var answer = response;
        alert('reponse' + answer);
        if (answer == 'false') {
            alert(getMessage('You are not allowed to order as there is an existing request for this customer'));
           return false;
            alert("else if alert");
            return true;
I'm getting the alert message but form is getting submitted.
Tried with getXMLWait(), it is getting supported
2 ACCEPTED SOLUTIONS
@is_12
this worked for me in onLoad catalog client script
I hope I answered your question and you can enhance it further.
function onLoad() {
		var element = this.document.getElementsByClassName('btn btn-primary btn-block text-overflow-ellipsis ng-binding ng-scope');
		element[0].style.display = 'none';
Output:
23 REPLIES 23
@is_12
you will require 2 onChange client scripts i.e. 1 for account and 1 for contact name
both the client script will have similar scripts and will show error on respective field/variable when validation fails.
@OlaN @Ankur Bawiskar
Requirement is to
  1. when agent is ordering the item from configurable workspace then write a logic as follows.
    1. On change of primary contact, fetch the primary contact's account and then go to RITM table and check for the catalog item and the account fetched from primary contact. If there is an existing record then restrict the agent from ordering and also display the alert message "You are not allowed to order as there is an existing request for this customer"
@is_12
I already suggested to use 2 onChange client scripts
When you use onSubmit with GlideAjax, there are challenges that the form gets submitted by the time the ajax function returns the value.
@Ankur Bawiskar one is on the contact & other one you are telling on the account(account is a readonly field)
@is_12
if account is readonly then only 1 onChange client script i.e. on Contact should be sufficient
