How to add multi row variable set variable values and set on different field
Ram141
Hello Team,
Is it possible to add Multi row variable set values and pass those value on to a separate field present on task table.
Anil Lande
Yes you can access MRVS values and put it in another field on form or in another variable.
Please check below links:
https://community.servicenow.com/community?id=community_question&sys_id=5117876bdbd18110382a82630596...
https://community.servicenow.com/community?id=community_article&sys_id=4b54ab561bfa445cada243f6fe4bc...
https://community.servicenow.com/community?id=community_article&sys_id=2a508caedbf47f48d82ffb2439961...
Anil Lande
Please appreciate the efforts of community contributors by marking appropriate response as correct answer and helpful, this may help other community users to follow correct solution in future.
Anil Lande
Anil Lande
Anil Lande
Anil Lande
