Introducing Knowledge Center Smarter Knowledge Management with Now Assist AI and Advanced Editing Knowledge has never mattered more—especially with AI depending on accurate, fresh, well-structured content. Knowledge Center for ServiceNow's Knowledge...
What's new in ServiceNow Otto for Creator Brazil Patch 2 and Australia Patch 8 (November 2026 store release) Jump to SPP in the EU Models Rules and skills Getting started What's next New to the series The ServiceNow Otto for Creator Articles Hu...
Most organizations control their AI agents with policy. A gateway checks a rule before the agent calls an API; a policy engine decides whether a tool call goes through. That works until the rule needs something the request doesn't carry: who answers ...
USEM Launch Details USEM - Unified Security Exposure Management - is the next evolution of Vulnerability Response (VR) USEM features are made available in Vulnerability Response v30x Vulnerability Response v30x was officially launched and released...
Employee Journey Management: Quick Start Guide Updated for Australia Release Welcome to the Employee Journey management (EJM) Quick Start Hub Employee Journey Management (EJM) is one of the most impactful capabilities within ServiceNow's HR Ser...
Hi All,Thank you in Advance! I am currently reviewing the Major Incident Management functionality related to Communication Plan definitions.The requirement is to enable the MIM process to use the standard ServiceNow Major Incident communication plan ...
Hi Community, I am exploring service now and have queries related to display and reference topics Reference field type is used to refer data from other tableFor example, name-reference- userAbove for name field data shown from user tableMy doubt i...
Ask any IT admin where the week went, and you'll hear the same things: password resets, access requests, tool approvals. Why not automate them with Flow?! The easiest place to start is the everyday work that eats up your time. Most of it isn’t tech...
i am facing servicenow PDI inactive issue .I am refreshing it again and again but the instance is still inactive any suggestions to reslove the issue
Moved an upset set containing name change and short description for a record producer to uat. Throw up an error about a newer version in uat. Accepted remote but this reverted the update done in uat to the old information while dev still has the upda...
Hi Team, Unable to add control record to a adhoc-created risk. Eventhough both risk and controls are related to same entity. Please see the attached screenshots in sequence.. Help me understand if this is an expected behavior.. or is there any way t...
Not all our clients need to see the Now Assist icon in the banner.Is there a way to limit the view to a specific role?Any help greatly appreciated.Thanks.
How to Another option like 'Private' under 'Download,Remove,Rename' options of attachments as shown above? Is it configurable or needs to play with source code ? I can see component in debug as 'now-dropdown-list'. Not sure what it is in Servicenow ....
Requirement - IN HR Agent Workspace, When someone attempts to change the state of HR case to suspend a popup form should appear asking for reason and a due date in HR Agent Workspace. I am using a client script to display the popup form using g_moda...
Hello ServiceNow Community,I am unable to access my Personal Developer Instance (PDI).Here are my instance details:Instance ID: dev394172Instance URL: https://dev394172.service-now.comRelease: AustraliaUsername: adminLast successful access: October 7...
Created custom integration user account in the DEV instance to create/update user records from Okta to ServiceNow. The account has been granted admin and required integration roles and is configured as a web service enabled user. but, some user table...
When records are imported through Data Import Sets, the record numbers are not being generated in the correct sequence. Instead, the numbers are getting assigned in a jumbled or non-sequential order.Also, when we create records manually, sometimes a ...
Hi All, I am trying to add a choice value "Very effective" in control effective assessment of my PDI. The control effective assessment is already in Published state. I tried to Copy and made changes then published but its not updated. I couldn't see ...
Currently when a new catalog item is requested, the category,detailed description and meta,picture are optional. Going forward it should not be like that without affecting existing catalog items ,how can we proceed with system ui policy or onsubmit c...
We want your journey here to be as great as can be, so we have put together some links to help you get quickly familiarized with the Community.
| Subject | Author | Posted |
| an hour ago | ||
| 3 hours ago | ||
| 3 hours ago | ||
| yesterday | ||
| yesterday |
