04-11-2021 07:06 PM
In my flow designer, I created a workflow where when a catalog item [sc_cat_item] is requested, an approver is assigned to RITM and a task [sc_task] is created.
But, Service Catalog Trigger does not work in Flow Designer.
When I checked Process Automation > Flow Administration > Today's Exections ,
there was no record of the history of the workflow running, so I guess the trigger is not running.
When I test the workflow in the flow designer, it works fine.
I'm having a very hard time getting the flow designer to work, so I hope someone can help me.
Service Catalog
04-11-2021 11:55 PM
Your flow is configured to run as which user? System User?
also refer this link which talks about some workaround for BR on RITM table
Flow not triggered by Service Catalog
04-11-2021 07:21 PM
Hi
ServiceNow has to know which Flow you want to use for your catalog item. Therefore select the Flow as follows:
Kind regards
Maik
If my answer replied your question please mark appropriate response as correct so that the question will appear as resolved for other users who may have a similar question in the future.
04-11-2021 07:58 PM
Hi
Thank you for getting back to me so quickly.
I'm working on that setup as well, but it's not working.
Is there any other reason you can think of?
I'd appreciate it if you could tell me.
Haruka Kubota
04-11-2021 08:27 PM
Hi
please provide more details concerning your setup and configurations.
Kind regards
Maik
04-11-2021 10:44 PM
