Flow designer email body
Shoheb Shaikh
Hello Experts,
I am trying to bring variables value to email body using flow designer. Below is the thing that I have designed. Email is getting triggered but the variables value are not getting populated on the email body.
How to achieve this?
Shoheb
11 REPLIES 11
ServiceNow Use6
Maybe add 'Get variables' option ahead of this step.
Suman P.
Allen Andreas
Have you included a get catalog variables activity in your flow as one of the first things after the trigger?
If so, then you can use the variable pills there.
Yes Allen, Catalog variables activity is added and using the values, I dragged and dropped the variables in the HTML body but still no luck.
Can you share an example of the notification result?
Is it showing nothing or not showing what you expect to see? Is "some value" still there?
Please mark reply as Helpful, if applicable. Thanks!
